Vacuum control box rebuild (pictures) (1 Viewer)
Wadesters
Newnan, GA
Website
www.cwcruisers.com
FJ45 was not running when I got it. Does this box need to be rebuilt (or can it be)?
What type of new hoses do I need?
Thanks..
yes it can be rebuilt, IIRCC there is a diapgram inside
if staying with vacumn shift keep it
going with floor shift rebuild it
no idea on the hoses
You can also test the functionality of the vacuum shift on the transfer case by applying vacuum to the lines. If your 4WD indicator light is working you will be able to determine everything is fine down at that end.
I have everything apart so was hoping to check / overhaul before reassembly
