vacuum advance has fuel in it??
Long Island, NY
On this 60 I just bought (im very picky) I am going through everything with the factory service manual, making sure all things have the right resistances, voltages, etc...
also giving it a tune-up, and so forth.
When I was setting the timing, as the FSM indicates - detaching the two vacuum advance lines. The upper line (one closest to the distributor body), spewed fuel out and seemed to have filled that diaphram with fuel.
Is this normal? If not, is the diaphram toast?
How to investigate and fix?
Thanks again group,
dallas
Welcome to the 60 forum.
This is not normal. I would pull a vacuum on the diaphram with a hand pump and clean it out and make sure it holds vacuum. One of these lines has a check valve which should be close to the distributor. Check and make sure the check valve is there and then test it. The main diaphram which you are talking about gets vacuum from the port on the carb but don't see how fuel would get all the way there. Check all four of
the vacuum lines on the side of the carb by the valve cover to make sure they are all correct.
Howdy! Obviously, a vacuum line should only have air in it. I would guess that the P.O. squirted something else in there, like WD-40, carb cleaner, Hot Shot starting fluid, not knowing any better. As Kevin said, if the diaphram holds vacuum, then your good. If you continue to get liquid coming out of a vacuum port on the carb or intake manifold, then it is hooked up way wrong. Maybe it has been plugged into the fuel vapor canister. John
