Vacum pump
Nairobi, Kenya
I've wasworking on the brakes on my HJ60 the other day and realized that one of the hoses on my vacum pump is missing. The hose on the top of the vacum pump is not there, and I can't seem to figure out where it should go, even after looking at the FSM and Haynes manual. Can anyone help?
John
John ,is it a small outlet?
I cant remember what the 2H looks like but my 1HZ has a small and large hose attached to the pump.
The large is for the brake booster and the small is for the aircon fast idle.
If it s not doing anything best to block it off
if it is small hose it is for your vacum actuator solenoids for your 4 WD actuator, if this hose is off you will not have 4X4.
Daryl
umm, it wouldn't be the location tab that you are looking at? this does not have a hose to it but kind of looks like it should...
cheers
I'm not sure even from looking at the FSM. It's a very small tube that is on the top of the vaccum pump, but I'm sure that looking at the manual it shows a tube going on to it. I'll have a look at it again and try and take a pic if I cant figure it out.
John
