V8 swap guys- cut off the old motor mounts?
Dallas
Website
www.octagonmma.com
Hey. WHat can I expect when cutting off the old mounts? My thought was to grind the old rivet heads off and knock them through the frame? Will this work or do I just cut it all off right even with the frame rail?
Never done this before.......:rolleyes:
Those rivets are beasts!!!
Toyota didnt make them sissy-lala. I have removed almost all the original brackets and mounts, and the last ones i grinded off were on the shock towers and took a couple hours to hammer them in, and clean all the rust behing the bracket and POR 15. So just get busy and they will be off before you know it.
Yep, grind off the rivets and knock them out. If someone wants to reinstall them in the future, they can always be bolted back in.
What about the rear mounts?
x2 on drilling. I found it best to grind a flat on the rivet head, center punch then drill with a 1/4" drill through. Then cut the head off with a chisel and drive the rest of the rivet through the frame. Sounds hard but a good drill bit makes short work of the rivet. Screw machine length bits from MSC, J&L Industrial, McMaster-Carr etc work great for this...
Nick
Using a 4.5" Makita grinder I ground the front rivets flush, pryed the mounts free, and punched the rivets through into the frame. The rear was tougher since you don't have much room with a larger grinder. I ground the top rivets flush and used an IR mini to grind the bottom rivets flat then I drilled them out. The best part was the Norton abrasive 36 grit hitting me in the face. I look 10 years younger!
Seriously, what do I do with the 4th mount that's welded in there?
I also just got done with it. The motor mounts are very easy to remove since you have a lot of areas to put a prybar into. So with that said i torched the heads off, ground them smooth, and used a crowbar to remove. On the shock towers i had a ^^* of a time so i had to take the torch and heat them up and then blow a hole right in the center of them and this relieved enough pressure that i could then drive them through the frame with a punch.
Good luck
