V8 conversion experts- How to tie into the LC ignition wiring? (1 Viewer)
alex e
Dallas
I'm using the Downey manual to install a V8 (350 TBI) and their explanation of engine connections to execute (two 12V, VSS, ground, fuel pump, & CEL) make sense. I have the wiring harness labeled from where the seller removed it from a 60. My main question is where / what wires do I splice into or connect to use the ignition? My engine has a pair of wires labeled IGN coming from it. Also do I ignore most of the old 2F connections on the 40's harness?
I don't think I see how to do this in the Downey manual.
Any help? :frown:
Alex
alex e
Dallas
I figured it out. Wires from starter into old connection on 2F harness...DUH.
Brea, Calif.
Alex, most of the time the Engine Harness for TBI does not include the ignition system (except for the plug that plugs into the Ignition Module inside the Distributor). For wiring between Coil/Ignition Module/Distributor/ECU I can help, PM me if you need this circuitry explained.
alex e
Dallas
Go ahead....
Jim,
PM'd you.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
