v8 700r and driveshafts
Discussion in '40- & 55-Series Tech' started by talkinggoat, Feb 29, 2004.
  1. talkinggoat
    talkinggoat
    44
    May 25, 2003
    i've been reading over some of the posts and have found that quite a few people have made mods to the drive shafts. with a 350, 700r, and an adapter from sor, will i be able to keep all the stock drive shaft lengths? in other words, will i have to modify things behind the xfer case?
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,180
    637
    Dec 13, 2002
    Knee deep in hookers and gin
    It depends on your V-8 placement, but i think it would be very unlikely that your transfer case will end up in exactly the same place, meaning, yes, you would have to change your driveshaft length.
  3. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    There is absolutely, positively no possible way to keep your stock driveshafts.
    You will be enjoying yourself, no doubt.
  4. helocat
    helocat Tube is your buddy! Supporting Vendor
    610
    101
    Nov 2, 2002
    I run this set up with the AA adapter, and both shafts have to be modified. In fact I also used the AA front shaft smaller u-joint set up off the t-case. This is due to the 700R4 being off set to the right, :mad: Right into our drive lines. BUT the 30% over drive and the 3:1 first makes up for everything! 8)
    I have heard of people using the stock u-joint off the t-case in the front, but never seen it. (tight spot!)
    This is a great set up, you get the best of both worlds in gearing and auto.
    Mark
  5. Gumby
    12,180
    637
    Dec 13, 2002
    Isn't that where Nolen had to grind on the case a little to make his trans fit?
