Hello all, First time poster. Im currently working on a friends v8 100 Series ( I have a older cruiser myself) and it has some pretty concerning electrical issues.
It started by one day blowing the EFI no.1 Fuse while cranking. Then a new fault developed and it would not crank at all. I have narrowed down the EFI fuse short to be in the starter solenoid circuit. If i disconnect the single pin connector from the fuse box to the starter and then apply B+ at the starter side it does not blow the EFI Fuse. The engine will start and then stall straight away.
Other issues include
-Gear indicator on cluster not displaying anything
-Volt meter on cluster reading max (over 19V)
-P/N does not change state on scan tool
-scan tool unable to connect to the ECU and Transmission modules at all
-Engine will not crank via the Key (gets 12v signal to ECU in crank position, ecu not outputting 12V to start relay)
So theres a bit going on. Have checked all obvious things such as connectors etc. It may well be possible that the EFI fuse should has caused an ECU failure But i wanted to confirm before we go down the path of replacing it,.
Cheers
S
Cheers
S
