Using the SST tool without removing the axle seal.
Discussion in '40- & 55-Series Tech' started by jackbrad, Aug 18, 2006.
  1. jackbrad
    jackbrad
    668
    Mar 1, 2006
    Charlotte, NC
    I put my front axle seals in before I used the sst tool to set up the knuckles.
    I think that the Factory service manual is saying that in order to use the SSt I am going to have to have them out.
    [​IMG]
    Here is the piece that is in reference... in green.
    [​IMG]
    Can I leave this piece out and use the seal as the peice...
    Or I am being lazy and just need to remove the piece and do it right?
  2. awp_cruiser
    awp_cruiser
    302
    Jan 18, 2005
    Seattle
    I think it is made to use the sleeve without the seal, or leave the seal and take off the sleeve??
    I would think that the cost of new seals and the maintenance issue with them would warrant new ones. So just pop 'em out and replace them and be done with it.
  3. Pin_Head
    Pin_Head
    14,527
    2,164
    Feb 6, 2002
    OC, CA
    If it was me and I needed to use the SST, I would use the sleeve as it is intended and either carefully remove the seals or get new ones.
  4. mustardfj40
    mustardfj40
    907
    3
    Jan 22, 2003
    Silicon Valley
    I did it without the seals, the measurement is really small...It's a simple but tedious job and I wouldn't want to do it twice just to get it right.
