Urgent: I need help wiring my running lights into my pull-switch.
As the title says:
Final date for approved safety inspection is tomorow, I have school till 1 and my safety is at 2.
Hopefully someone here can help me out.
Further explanation:
I had a short in the front of my truck and wasnt going to pull everything out, so I ran in a new power wire into a switch and spliced it into the rear running lights (plate lights, side marker lights) and into new power wires that I ran to my front markers.
:meh:
Worked great however for some reason it isnt 'safe' to have my running lights on a seperate switch.
But I'll give them a piece of my mind, :steer: (right into them)
Thanks,
-Emerson
use multimeter
Pull out your light switsh and use the volt setting on a multimeter to determine which wire has power when the switch is pulled out to the first click. (or consult a shop manual) and then wire the lights to that lead.
X2
Best Of Luck With The Inspection
Thanks,
