Urgent HDJ81 Help needed, Can't get 24V at the Starter Solenoid after repair
Laurentians North of Montreal, QC
Well Folks, I'm in Deep s***. Sorry for posting this in a separate thread on top of my starter thread, but I'm really in deep s***!!!
I've reinstalled the starter and the relays operate, but the solenoid won't budge.
I have checked the voltage converter: works fine. I get 24V at the starter in the start postion.
I have checked the solenoid (magnetic switch), it reads 3 ohms in one winding (power to ground) and 1.5 ohms in the other winding (power to starter motor).
I have bench powered the magnetic switch with 12V, and it hardly pulls at all. That would confirm it is really a 24V solenoid.
I have 24V at the starter main, but I only measured 12V at the starter solenoid. However, looking at teh schematic, I should have 24. I have checked the fusible link, it hasn't melted.
I'm stumped and bushed. I have work tomorrow morning and I need to figure it out, reinstall the starter, the battery tray and all the other nuits and bolts I took off to be able to get at the starter itself.... AAARGH!!!
If any of you with HDJ81s out there and a manual could verify that indeed, I should get 24V at the solenoid during start? It's driving me nuts, and I'm expected at work tomorrow 8AM!!!
Here's the schematic I have... If it's the wrong one, please let me know!!!.
Did I misss something???
Thanks in advance for your help, I really need it!
I once had a started suddenly show a bad contact between the connector and the wire of the solenoid. Obviously I only found it after tearing the whole thing apart and reassemble for nothing. :doh:
I'm not familiar with RHD but I'm pretty sure you can get to the starter from the wheel opening.
Have you tried jumping the solenoid wire directly to 24V ? The solenoid definately needs 24V just like the starter motor.
good luck !
Problem solved!
It turns out it was an inverted connection at the magnetic switch, which caused the thing to start with the hold coil instead of the pull-in coil!
I was not too happy with the manual (it's not the first time that I notice errors and mistakes in an FSM), which describes the specs as "should have continuity"... If the resistance value had been specified instead (around 1 ohm for the pull in coil and 2.3 ohms for the hold-in coil), I would have found out the problem right away!!! Secondly, the schematic, which seems to indicate I should have 24V, the solenoid is in reality powered by 12V... That could be, however, explained by the fact it is for a 1990 model HDJ80, NOT a 1991, JDM HDJ81...
Fortunately I had documented the job for posting here, so when I looked at my starter to the picture I took of it before I took it apart, I immediately noticed the error!!!
In fact, it was a fortunate error, because the crucial plunger ball bearing had fallen into the starter gear case during my initial reassemble and could have crushed the gears, had it lodged in between them upon a succesfull start!
I'll document the whole thing in my starter thread...
To all of you, please accept my warm thanks for your compassionate thoughts, I am sure it helped me get through it and back on the road just a few hours before I had to get to work!!!
Sincerely,
Christophe
