- Joined
- Dec 20, 2006
- Threads
- 6
- Messages
- 43
LC
What did you end up finding.
Mark
Mark
for all your help!
This is a classic case of a mis - diagnosed vehicle.
He told you it was the pan that was leaking, and after going through the work of replacing them he then discovered that the rear main is the actual cause.
So- he took the hit and did not want to charge you.
Sounds like a pretty upstanding thing to me.
Alot of shops would have called you and said " ya ah we are alos going to need to replace the rear main at $ XXX more money"
This guy may have had a bad experiece in the past or those "kids" he talked about may have mis-diagnosed a couple vehicles and this was actually a cheaper way out for his business. All he is loosing is labor hours.
I dont' know, but to me it sounds like he mis-diagnosed the leak source and busted his tail replacing the pans and now just wants you to have someone else do the rear main because he is beat or does not trust his guys ?
However, his customer skills clearly need some work.
Skim, Rook and Jason all make valid points, and I definitely see the logic. If that were the case though, why would he not want me to have any documentation that he had actually worked on the truck? (I know no one can speak for him, but I fail to find good reason for this action)
NO doc, cause he dosen't want you to bring it back for him to fix the oil leak he allready didn't fix the first time. And say look< I paid you XXX. to fix the oil leak and you didn't. Try again
