Content may include affiliate links. Please see terms for details.
OK, what I guess I'm really trying to ask do the upper control arm bushings have adjustments for alignment?
After a bit more searching, it appears the answer is yes.
👆 This is correct.The upper control arms is where all the adjustability is, there's none in the lower control arm. There are cam bolts on the upca's, once they are disturbed (moved, loosened, etc), you need to check alignment.
