2000 LC with 374K still running strong. Very much a weekend beach and road trip vehicle with some towing in between. Not wheeled hard.
Replacing original axle, original brake lines, lower ball joints, outer tie rods.
I've searched but posting some questions here. I was so tempted to ask if aftermarket bushings are better than OEM but at risk of my mother being called out as a whore, etc., I will refrain
About four years ago we were busy moving and I had (at that time) a local indy install upper control arm bushings and ball joint. Soon after the install I notice some bushing squeak when going over larger bumps (speed bumps) and has been driving me nuts.
Before I pulled the UCA, I checked the torque on both bolts and both were are 72 ft lbs thinking they might be over torqued.
Pull UCA and found this (pics below). Now I'm questioning everything. I assume this is NOT normal.
You can see in the second picture the bushing starting to tear after maybe 25K in 4 years??
So - I would ask opinions on OEM vs Aftermarket but any ideas as to why this might happen so that it is not repeated on install? Was it a half-assed install job? Crappy bushings (I think these are Moog or other)?
Open to inputs BEFORE reinstalling. Thanks!
