The part I am confused about in an otherwise stock setup (sway links, uca, lca): Is travel the same when height is greater than stock? I'm probably mistaken which is why I'm asking. I don't understand how, or where the added element of wear is introduced with a lift. I mean simple answer is "not stock" but that not really what am asking.Yes and yes if you are looking 2-inches (and up) higher than what it was originally set at.
That's my crux here. If the suspension isn't traveling any more than stock, how or where is component wear increased? Is the static height a factor?Travel with a “lift” is identical to stock - you’ve only changed the static ride height with a “lift”.
Got it. Good explanation here.Yes.
Your cv will have increased wear due to a higher angle.
Your upper ball joint will also wear quicker. Since there's no increased travel, when you bottom out, usually it's you upper ball joint that binds and limits further travel. That is a cause for premature BJ failure.
Stock - you have about 4 inches down travel and 3.5 inches up travel. When you lift 2 inches, you get 2 inches or so of downtravel, and 5.5 inches of uptravel. Well, it's not hard to max out the downtravel, and cause more wear on your BJ
He’s talking about bottoming out the downtravel, which, on this torsion bar IFS bull$hit, translates to either the shock hitting full extension or the upper ball joint binding as the UCA moves down.Got it. Good explanation here.
When you say "bottom out" you mean reach full compression in the front right? Would aftermarket bump stops prevent the bottoming out, or have no impact?
Ohhhhh I get you know.He’s talking about bottoming out the downtravel, which, on this torsion bar IFS bull$hit, translates to either the shock hitting full extension or the upper ball joint binding as the UCA moves down.
I don’t think aftermarket UCAs are worth the expense, regardless of how much “lift” you have up front.Ohhhhh I get you know.
So the wear on these components can not really be prevented in a lifted application unless an aftermarket arm is used?
In applications less than 2 inches over stock, are the issues the same?
