How do you disable the DRLs?Why not just disable the DRLs?
Tried these on my 2013. IPFs flicker and pretty much blind people on DRL. Wish I had results above. Went back to halogens.
Mines a 2013.Just went out and double checked:
I have zero flicker with my DRLs using IPFs.
2008
Mines a 2013.
I live in a semi rural area. Day time head lights are required and the DRL is helpful. The harness I was looking at will not help. So I adjusted auto feature on head lights to the highest setting and will have a little flicker at low light. These IPF LED’s rock. It’s worth the flicker issue.
Just wait. You will unfortunatelyJust went out and double checked:
2008
I see so many people driving around with only their DRLs at night, that
Touchscreen menu
If that is a touch screen menu option I will shut that s*** off tomorrowI see so many people driving around with only their DRLs at night, that
Touchscreen menu.
I will check in the morning - I hope it is that simple. Appreciate itDon't know if it's the same on your 2011 LC200, but on my 2013 LC200 it's under Vehicle Customization:
Setup > Vehicle > Vehicle Customization > Lighting Options > Daytime Running Lights On/Off
HTH
There is no system setting option to disable DRLs on the 08-11sDon't know if it's the same on your 2011 LC200, but on my 2013 LC200 it's under Vehicle Customization:
HTH
Unfortunately i dont have the screen option of vehicle. No go for a 2008No, it's there. Just need to keep digging.
Vehicle > Settings > Lights > DRL
If you absolutely can't find the setting, you can disconnect the little resistor that sits in front of the power steering reservoir. Early years have the resistor, but later years apparently use pulse width modulation for the DRL instead, which is why the later years are more prone to flicker when LEDs are installed.
