Upgrading Brakes, Which Brand?
yup both.....i drive aggressive
rear disks $399.00
front ranges from $649.00 to $349.00
ANYBODY USE POWERSLOT or other brands????
The PLUS ONE says 18 inch wheels or bigger......$1,000.00 for front and back
Ponte Vedra, Florida
I would think the OEM brakes with new fluid would give you the best stopping distance. The vented brakes look neat but only provide better fad resistance after repeated high speed stops and may give longer stopping distance because they have less surface area because of the vent holes. Unless you can find a manufacture that has a special system designed for the 100 series that provides proven results I doubt you will improve on OEM and may end up with worse braking performance.
ace10
Another one bites the dust!
Rural NoVA
6K pounds and "agressive" driving style.
please tell me that you don't live in the DC area, as my family and I are not not always on the roads in a huge SUV. :frown:
Pasadena, CA
Jim_Chow said:
How fast do ya wanna stop? Brembo also makes front rotor/caliper kit for 100's that uses Ferrari F40 calipers. You need 18" wheels.
Yep the kit cost $5600.00 USD plus tax, shipping and handling to U.S.(Made in Italy)
Orange County, CA
5600 is way too much for a 2 wheel big brake kit. Anything over $5K should be a 4 wheel kit. FWIW, my stoptech 4 wheel kit retails for $4800. They have a 2 wheel LX/LC application for a little over 2 grand
Los Angeles, CA
I've got DBA Gold rotors front and back and they work great with the stock brake pistons. www.dba.com.au. Word is the stock pistons on all toyotas are high-grade forged aluminum, so just changing the rotors made sense to me. Performance improved dramatically. They also look cool and are pretty reasonable in price.
Orange County, CA
LC-Turbo said:
what did you get and pay...prices vary from $1,500 to $3,500.
my budget is $1,500 max
I got the 4 wheel kit for the C32 AMG. 355mm front, 328mm rear. Retail price was $4800 I believe with the cross drilled rotors. I paid much lower, but I got sponsorship for the car.
their kit for the LC/LC is 2600 for the slotted rotors, so I guess I was mistaken in price. $1500 is pretty low when looking for a big brake upgrade. Its hard to find them used for sports cars at that price, let alone a LX/LC. Your best bet would be rotors, pads, and lines.
Stoptech has some great technical white papers. Your stopping distance is really controlled by the traction of your tires, if you can lock up your stock brakes, then it doesnt matter how large your brakes are. BBK's are really for fade resistance during repeated stops. Or in my case....looks.
hoser
Bay Area, CA
Above stopping distance, I would say BBK's allow for better brake modulation. But maybe equally important as fade resistance for an SUV.
Cuyamaca, CA and Las Vegas, NV
I got SP slotted rotors from www.raceshopper.com. If you want bling, they can be had with the nickel plated too. I'm using Hawk pads. The combination works really well. My braking improved, no doubt.
I only did the front so far. Rear is still stock rotor and pad.
Anyways, I think you would be looking at under $700 for front and rear rotors plus pads. All bolt-on, etc. Well under your budget.
You should give them a call.
really.................
this is what I'm thinking, using both.
Stop Tech Calipers will work on stock rotors , a set goes for about 1,000.00.
Then I'll upgrade my front rotors to the crossdrilles and slotted as well.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
