So the previous owner put some nice willow cross drilled disc brakes on the front wheels and I decided to finish off the brakes by adding a TSM disc brake kit to the rear (rear drums were shot). I should have taken pics of those but oh well. So yesterday I put on a new brake master cylinder b/c the old one didn't work well being that it's designed for drum brakes.
92 toyota pickup 4x4 6 cyl
http://www.autozone.com/R,APP15962/...partType,00007/shopping/partProductDetail.htm
Fenco new / Master Cylinder (Brake System) w/ reservior $64.99 (no core charge)
Replacing it was easy. 4 bolts + lines to removed the old mc. I had to grind down the pushrod 1/2 though to keep the brake pedal from being too high. In all it was a quick replacement but bleeding the brakes took forever. Yes I did bench bleed the master cylinder. I tried bleeding the brakes by myself with a pump vacuum but that was just a waste of time and I went and got help.
Out with the old, anyone want a master cylinder?
In with the new:
I also got a willow proportioning value which really works nice! I didn't bleed the front brakes enough so the rears were locking up. I was able to reduce the rears enough to make my brakes safe temporarily.
I got a heat wrap for the mc b/c the headers really heats things up.
In with the new:
