Upgrade front bumper?? Remove AHC??
Coeur d'Alene ID
I have a 98 LX470. I need to upgrade the front bumper and get a winch too.
What recommendations does anyone have?
Also I am thinking that I should remove the AHC, which is functioning properly, because I do not want it to fail while I'm out wheeling'. And I'd like to get more aggressive tires too. I will need more clearance so I will need a lift. Any suggestions for lifts on a LX470?
geanes
Austin, TX
I ran my 98 LX470 with an Ironman Bullbar for a year with AHC and saw zero issues. I did have to crank the TBs a few turns to get back to neutral pressures, but was fine from there on even wheeling over rocky passes in CO. Unless you plan on going "all-in" on your rig (rear swingout bumper, rack, RTT, drawer system, dual battery, etc.), I see no reason to rip out a perfectly functioning AHC system. There are others here that have built out their rigs and still run AHC, though they replaced the rear coils with beefier versions from King.
If you go with a bullbar, be aware, the grill on the LX is attached to the bumper and will hit the bullbar when opening if you don't plan for it. I fabbed up new spacers that have a 1/8" declination so that my bumper is ever so slightly angled down. It's not noticeable unless you know to look for it. But, my grill clears the bullbar with no issue.
A synthetic line winch will only add about 95lbs (maybe even less) to the front. Nothing a crank or two of the TB can't mitigate to keep neutral pressures inline.
Calgary, Alberta
I have run my 2001 with AHC and a ARB Sahara bar with winch. Just adjust the suspension accordingly, per geanes suggestion. I recommend an AHC spacer lift from Japan 4x4, if you want to keep it economic.
If you really want to go much bigger, expect to shell out $$$.
Dover New Hampshire
ARB Delux bar 100%. get the 03+ bumper though, its a direct bolt on, and you have the option to get fog lights, where on the 98-02 you can't. My family has owned ARB parts and bumpers for 10+ years and are happy with every single one.
Columbia, SC
You don’t need a lift to go to 33” tires w ahc. I have 285/75/16’s with the AHC and have yet to rub. If you read the faq’s, even with a lift, 33’s are about the max on a 100 series. There are a couple guys w 35’s but they’ve done crazy mods.
Coeur d'Alene ID
Ok thank you. That is great. I'll jump into the FAQ's
1sar39
Salinas, CA
Heres a link to a thread I started when I pulled the AHC tb's. It's a good option If you decide to keep the AHC.
Coeur d'Alene ID
Thank you!
