Fj80oregon
GOLD Star
sorry not my thread I meant my truck is posted here. So you can see it’s a Slee bumper.This is my thread with my truck and bumper in the picks.
What do you want for it?Thinking about selling mine if your interested let me know not a scratch on it.
Early Xmas/birthday(same day) present for me thanks to fj80oregon.
This is by far the best looking 80 series rear bumper IMHO. I can’t wait to get one for the LX too. Delta says they’re planning on adding rear quarter protection for their bumpers so might have to wait and see how those look.
Anybody know where to find the cover/trim on the rear part of flare where the stock flap used to mount? You can see it in the Slee pics if you zoom in. I thought there was a vendor here that sold them. It basically dresses/cleans up the flare after mudflap removal.
I already have a few times. It seems to fix it for awhile.... And then I drive to fast in the whoops and sand dunes at Sand Hollow.Adjust the latch. Mine hasn't popped open in close to 20 years.
Is there anyway to limit the movement of the spare tire? The arm itself doesn't move but the mount is flexible enough to make the spare move around a bit.
I wish I could understand what you're saying . Should there be a slight angle to the tire? Mine is just straight up and down. So to explain this better, if I go and put my hands on both sides of the tire and pretend it's a steering wheel and move it like I'm turning left and right there's movement because the mount is a thinner piece of metal with no support. In the beginning i just thought it's probably designed this way, kind of like skyscrapers where they make them sway with the wind allowing them to be stronger. But it's just annoying to see the tire shake when I'm drivingI think I understand, but some pics might make it clearer.
The tire should be preloaded against the swing arm “upright” approximately 3/16-1/4” when install properly the tire will be indented slightly by the “upright”.
Cheers!
You can adjust the movement of the bracket with the three bolts I believe you loosen the bolts push the tire agains the upright than move the bracket in 1/4 inch and tighten. Then when you latch the swing arm it sucks the tire into the upright and it won’t move. This works for sure I did it. Refer to your morning instructions to make it more clear.I wish I could understand what you're saying . Should there be a slight angle to the tire? Mine is just straight up and down. So to explain this better, if I go and put my hands on both sides of the tire and pretend it's a steering wheel and move it like I'm turning left and right there's movement because the mount is a thinner piece of metal with no support. In the beginning i just thought it's probably designed this way, kind of like skyscrapers where they make them sway with the wind allowing them to be stronger. But it's just annoying to see the tire shake when I'm driving
I'll check it out. There's no actual "loose" movement. Everything is tightened down correctly. It's just the metal "bending" ever so slightly but not in a way that would damage or warp it.You can adjust the movement of the bracket with the three bolts I believe you loosen the bolts push the tire agains the upright than move the bracket in 1/4 inch and tighten. Then when you latch the swing arm it sucks the tire into the upright and it won’t move. This works for sure I did it. Refer to your morning instructions to make it more clear.
Fantastic! I didn't realize it had to be firmly against that. Thank you!!The tire should make very firm contact with this piece.View attachment 2623345
