Update: WATER=Yes. TruckWent BERZERK: Advice?
where are the outlets for the sun roof drains?
There should be 4 outlets I think. The front drain holes outlet behind the front tires and the rear drain out in front of the rear tires, but I am not 100% on that.
Yep. Two you can get to in front, and two in the back that you can’t… at least not easily.
The rear sunroof drains are piped to the body behind the rear tires, pointing straight down, behind the wing of the bumper skin. It is a ~5/8" round pipe sticking out of a hole with foam insulation surrounding the opening.
I'm not as sure of the fronts, but behind the front fenders rear of the front tires at the base of the a-pillar is a common spot.
The part I find hard to get to is the top opening of the rear drains.
If anyone knows a trick to accessing that entry part… ?
I don't.
But if you park the rig nose up on an incline and water poured into the tray promptly appears out of the drains, there shouldn't be any need to clean them.
I don't.
Ya, my drains are fine. I just have a weird little curiosity case not really even relevant here, so I wondered if someone knew some trick to accessing the top. Low priority stuff.
I wish there was, but I’ve had the same curiosity over almost a dozen vehicles with sunroofs and had to accept this isn’t something the factories designed in to their engineering.
