Update need help Brake line routing question (1 Viewer)
South west utah
*Update: I got this blown brake line off and I think that it was routed wrong. I am ready to install the new ones but I was wondering if anyone could post a quick picture of the proper routing for the front passenger caliper to axle brake lines?
Getting ready to replace the front brake lines this weekend. I just finished reading the FSM and everything seems clear enough.
I am just looking for clarification on one thing. If I only replace the front lines and don't get air into the master cylinder, do I still need to bleed all 4 calipers, and lspv or can I get away with bleeding the fronts only?
Also just to double check, assuming I need to bleed everything the proper order is passenger rear, driver rear, passenger front, driver front, and lspv?
Thanks everybody
Thanks everybody
If it was mine, I would still bleed EVERYTHING.
RR, LSPV, LR, RF, LF, LSPV. Yes, LSPV twice. Don't forget to lift the handle (rod).
Haha yes, I just remembered I have access to a pneumatic bleeder, that should make this job a bit easier.
I am pretty sure the only reason this stainless brake line failed was due to improper routing.
This is the orientation that mine were in when I replaced them. I don't know about aftermarket but the OEM lines are kind of hard to screw up because they only really fit one way.
Thanks, I finally figured out that the existing hardline was not oem lol, it was about 4 times to long. I got the correct oem line and it was very easy to figure out the routing at that point.
