BlueCruiser84
Love this video. And the acting is topnotch.
Interesting, what your saying here.
I staked slip joint side joint on my front DS on my 80 before taking it to the drive line shop for joints and a balance after 280K miles. They told me it was out of phase, I said it has been in that phase for 280K miles. They insisted it was out of phase and when I got it back they had put it “in phase“.
Now I have a drive line vibration?
Thanks for this info.
devo
thanks. what do i call the part that bolts to the shaft? the non splined yoke? i mean how do i distinguish between the two different types of yokes i guess is what i am asking. <edit: flange yoke which is bolted and sleeve yoke which is not>This part is the ujoint. The parts that hold the joint are the yokes.
Untitled by Adam Tolman, on Flickr
spike. /thanks/ for these.Vibes can come from many places, and the original front configuration is only correct at stock height, so if you have a lift all bets are off.
For what it's worth, from the '94 FSM:
U joints do not move at a constant speed when there is any angle between the input/output shaft and the driveshaft. They are accelerating and decelerating as the driveshaft rotates. This acceleration/deceleration creates a force ( force = mass times acceleration ). The smaller than angle, the less force is induced into the drivetrain. In order to eliminate the force, the u joints are set up at the same angles, and in phase. The forces cancel each other out.
When the angles are not equal, or the u joints are not in phase, the forces that the u joints are creating do not balance out. This is what causes the vibrations.
Double cardan joints work the same way, except they are designed to guarantee that the u joint angles are identical. So the forces are balanced at the double cardan joint. This requires that the u joint on the other end not be operated at the angle, otherwise it will create forces that cannot be canceled out. This is why the pinion has to be in line with the driveshaft with this type of driveshaft.
thanks. that’s hard core but i will print it and read it...Driveshaft 401 & One-Ton High Angle CV Driveshaft...
www.pirate4x4.com
What I was trying to explain in words is so much better explained in the spicer video.
