The PO was in a tight spot on his last oil change when the pan stripped out. Obviously don't know the full story but here's what I'm left with.
Dorman Products - 65109
This was his temporary solution. I'm trying to fix the problem for good and need to know I feel anyone has any suggestions on how to remove this uni drain plug. Preferably with out dropping the oil pan. I didn't install it but it looks like the wing anchor inside the pan should rotate but with the drain hole so small I've tried magnets and small screw drivers to get it to line up and come out to no avail.
Thanks in advance.
Thanks in advance.
