My temperature guage has been quite high. I decided to put in a guage that gives a readout in Degrees (F) so I could see if I was having guage issues, or if I should be concerned about the coolant temp. I bought a 14 dollar temperature guage - (100 - 280) - and herin lies the issue.
When installing it (it is a mechanical guage), the end sensor was too long to fit in the fitting on top of the head without touching the head itself (the bottom of the coolant channel). Anyway, I installed it and torqued it down enough so it would hold pressure, and not leak, but the guage sensor is definately touching the block.
My questions are:
1. Can I cut the sensor in half allowing coolant to flow completely around it? I wasn't sure if there was some kind of liquid conductor inside the sensor wire.
2. Should I leave it how is is, realizing that the readout will be higher as their is contact with the block itself (assuming the block (head) actually gets hotter than the coolant - I'm not really sure)?
3. If I leave it, what should the temperature be on the inside of the block at the bottom of the coolant channel? (It currently reads between 180 and 230 depending on the situation.)
TIA
My questions are:
TIA
