Does someone know what the size is for that union that goes from the oil pump tube to the underside of the block? Into the block is 12mm x 1.25, but sure what the tube compression side is, 14mm? 17mm? And would it be available at the local ACE? Been trying to get ahold of ToyotaMatt, I know he sells them....but have not heard back
PRO TIP; don't forget to remove this fitting when you are swapping blocks!!!!! Grrr, completely held up my engine swap this weekend.
