Uniden 538W
Uniden PRO-538W Features:
40 AM Channels operation
3 NOAA Weather Channels, 162.550, 162.400, 162.475 MHz.
Switchable PA Mode, Instand Channel 9 and Waether Channel switch.
Variable Volume, Squalch and RF Gain Controls
Industry Standard 4 Pin Face mounted microphone connection.
13.8VDC Positive or Negative Ground, Less than 2 Amps of power required.
Compact design, 6.9"W x 2"H x 8.3 D
Exceptional receiver, Sensitivity os 0.5 microvolts for 10 dB; (S+N)/N typical
Front fire speaker.
Rear mounted jacks for PA Speaker, and External Audio speaker.
Uniden 2 Year Limited Factory Warranty
Uniden PRO-510XL Features:
Switchable ANL, Volume and Squalch Control.
Very compact design, 4.5"W x 6.75"D x 1.4"H, Weight of under 2 Pounds.
Dual Conversion receiver 1st IF: 10.692 MHz, 2nd IF: 455 kHz.
Excellent receiver selectivity, 6dB @ 7kHz, and 70 dB @ 10 kHz.
Image Rejection of 80 dB, Better than many high dollar radios.
7 Watts of Audio into 8 Ohm speaker, enough to even the loudest truck installations.
Rear panel external speaker jack, allows you to put on an even more powerfull speaker.
Uniden 2 Year Factory Warranty
It is larger but it will fit. It will stick out a lot further though.
Also this is a better radio and I've seen it fitted below a Pioneer head unit.
Midland 79-290 AM/USB/LSB transceiver with with 10 NOAA weather channels.
Detachable Face plate control panel.
Output Power:
12 watt SSB
4 watt AM
On/off volume control.
Variable squelch control.
Last channel recall button.
LOC - DISTANT button.
Mic gain button.
Instant Channel 9 and 19 button.
4 channel memory
Coaxial Coarse & fine tuning
Dual Channel watch Function.
All channel Scan Function.
Frequency or channel display functions.
CB / WX band selector button.
CB Mode Selector Button.
Jacks for external speaker
Includes
Dynamic mic
Industry standard 4-pin mic connector
DC power cord
Mounting bracket and hardware.
Size 6-1/4"W x 2"H x 7"D.
Pound, based on the info above, the 538 is a one DIN sized unit. The 510 is narrower and shallower. Therefore the 538 will not fit in the ashtray opening, but would fit in the dash if you replaced the factory deck with an aftermarket single din unit.
Ary
>> 538W: Compact design, 6.9"W x 2"H x 8.3 D
>> 510xl: Very compact design, 4.5"W x 6.75"D x 1.4"H
I have the 510xl in my ash tray slot and will safely say there is NO way the 538W will fit in the same location.
-B-
Thanks for the info guys. I've seen pics of the 510 and 520 in the ash tray slots. I'll probably go with one of those unless my radio craps out on me soon.
