uneven rear brake pad wear
Has anyone else seen this on their LC? Both sides of my rear brakes have uneven pad wear with the inner pad much more worn that the outer. One would think that would imply stuck or sticking calipers, but I have removed the pads and checked the caliper bolts and pistons. All move pretty freely. It's fairly easy to push the pistons back into their bores fully with a screw clamp without much resistance and smooth movement. I'm in California and my LC has seen very little snow. It is mostly garaged and driven on weekends. No off-road yet. So there is no apparent rusting at all. One thing I have noticed is that the caliper bolt boots appear to be fairly stiff compared to others I have seen on a car and maybe push the caliper frame inwards too much for new pads. Bud that would imply a dragging outer pad wouldn't it? So the only thing I can think of is scored caliper bolts or sleeves. I need to decide whether I should replace the calipers or not before completing my brake job. It's hard to believe I have 2 sticky calipers under these conditions though. I will end up cleaning and re-lubing the bolts and sleeves anyways.
dave mc
Sliding single sided calipers always wear pads unevenly, some more than others, just remove the boots and grease up the slides with some coppercote grease or similar antisieze, making sure you don't get too much in there and it leaks out onto your pads. Chuck a new set of OEM pads in and away you go.
I changed mine (rear) 2 days ago...
Both side have a little difference (1mm) and left side was more used (2mm).
I'm happy because the front and the rear of the old pads have exactly the same condition.
The most used has only 0.5mm height ... just in time !
You can find at Napa some special grease sold in small bag.
1 bag per calipper
usually indicates the slider pins/bolts are not properly lubricated. Clean them, clean out the holes, re-lube with specified lubricant. Molykote works well in this service.
