So the
heard some grinding from the back passenger's side tire and sure enough, no brake pad one side, 4 mm of pad on the other! Looked at the rotor and noticed it's been turned quite a bit and was too thin to be turned again. Driver's side brakes had about 3-4 mm left on both pads and the rotor looked new (~18mm thick).
I figured I had a sticking caliper so I cleaned and lubed the sliders on the caliper. The sliders move very easy now but they seem to push the one pad into the rotor, as if there is trapped air in the slider chamber pushing back. I hope I'm making sense because something doesn't feel right. Should I be looking for a vent hole somewhere or have I had too many
to be discussing this right now?
