so, you replaced them yet ?
Right? I'm a little amazed at the odds with this one. I think my issue has to be electrical, so I'm going to take a look at the distribution cap.I recently just started experiencing this about a week ago as well after heavy rain and some deeper puddles. Time to start digging. Seems like you are on the right track. This thread came at the perfect time. Thanks
Any update on this? Did you ever get your O2 sensors installed?
I'm still waiting on the O2 sensors. I took a pretty good stab at getting the bolts off which included an Irwin extractor set, days of PB blaster, a torch and finally a dremel. No dice. The nuts have become one with the bolts. I have to take it by a muffler shop and get them to remove and replace the entire section of pipe.
I did however make a little progress in some other areas. After having the injectors flushed and fuel filter changed I noticed it cleared up about 30%, which was promising. I went ahead and replaced the fuel sock in the tank and that seemed to help a little more too. Problem is still there but it's not as severe. Im hoping to get the O2 sensors replaced this week and then continue form there.
The fact that the fuel filter/ sock replacement and injector flush helped makes me think at least part of the problem was a fuel delivery issue. It could be that the O2 sensors were getting bad readings and sending bad info to the ECU and the fuel system was too clogged up to handle it. Thats just wild speculation though...
Any luck with yours?
Thanks for following up. Where'd you end up buying the sensors from? Let us know how this morning's drive went.So I THINK the problem is resolved. I've replaced the 02 sensors finally and the last remnants of the power loss appears to be gone. I haven't driven it from a super cold start yet, but after sitting an hour or so it appears to drive normal again. I'll take it for a spin tomorrow morning just to triple check.
I'm not mechanically intelligent enough to diagnose exactly what the issue was, but it certainly involved the 02 sensors, fuel filter and fuel sock (to some degree) and I'm just glad to see an improvement. Here's a pic of the 02 sensors for fun. Left is front, right is rear.
Oh I missed that you had pulled O2 sensor codes! That would make the most sense... Nice and easy. Glad its fixed!
