Ugh...another locker Question...
Greeley, Colorado
93, diff locks...
should there be an audible "click" from the passenger kick panel when I turn the rear locker on??? It clicks when you turn on the front. The front is the only locker that will engage.
Fuses good...why only one click?
Chandler, AZ
I had the same problem, power from the locker switch to the 4wheel drive control box in the passenger side kick panel, but no output (or click) for the rear locker. The front works great. A new 4wheel drive control box is on the way from C-Dan.
Greeley, Colorado
Definitely would like to know if that fixes it. BTW, how much was part?
Chandler, AZ
Swapped in a known good unit, locked right up. Don't remember how much the new one was, C-Dan quoted it and I said order it. The only other one he has sold was for his retrofit on his truck. The FSM has tests to determine what's bad.
