U-joints
:cheers: Hi guys
I was wondering about the u-joints in my lx 450 ... the ones that are on the truck have grease fittings ... I did grease them but have a feeling that they were neglected .
Do the factory Toyota come with grease fittings ...I would like the option of the fittings.
What brand do most of you guys use .
I have the vibration through the transfer case ... kind-a feels a little ruff at diffrent speeds but smooths out at higher speeds ... is this normal for these trucks .
All my shaft angles look fine ... no sounds from the transfer and the fluid was fine when I change the fluid.
Thanks
Greg
Utah
OEM Toyota U-joints have the grease zerk fittings on them.
Can't help you on the vibration issue though.
Bucks County, PA 45 min north of philly
Hey Greg
Look up "Buzzy 80" in the search feature. See if that is what you are talking about. I have the same problem and their doesn't seem to be a consensus on what it is. I was thinking about taking all of the theories and knock them off one by one and reporting back to the group.
