U-bolt/add-a-leaf question (1 Viewer)
San Diego
Hello all,
I just installed add-a-leafs on all fours corners of my FJ62 and it's an immediate, noticeable improvement in ride quality. The extra 1.5 to 2 inches of lift doesn't hurt either. It was well worth the 10 hours (yes, I am slow) to put these on myself. By far, the most difficult part was lining up the hole in the axle to the spring pin head! Once I get the original OEM shocks replaced this week it should improve even more.
After installing the front add-a-leafs, the u-bolts are a hair too short for my comfort level and I am going to replace them with longer bolts.
My question is:
When I replace the u-bolts, do I need to jack up the cruiser or remove anything other than the u-bolt itself? My plan is to support the u-bolt plate (not sure of the exact name) below the springs with a floor jack and remove and replace the bolts one side at a time with the wheels on the ground. I just want to make sure this is safe and I'm not going to break anything.
Thanks for the help.
In the valley of the Great Salt Lake.
If you replace the U-Bolts one at a time, you should be good. Since there are two U-Bolts per side, there should be one in place at all times to hold things together if you replace them one at a time. Your jack under the bottom spring plate should hold it in place. You have already had this apart for the add-a-leafs, so you know what you are doing.
Cruiserdrew
On the way there
Sacramento, CA
Obviously, be careful. The u-bolts hold the full weight of the vehicle. I would jack up one end at a time and put jack stands under the frame at a height to just allow the tire to touch the ground. That will keep the truck stable level and from falling on your head!
U-bolts are not meant to be reused, so you are doing the right thing. Far better to be safe than have one fail at a bad moment.
San Diego
Thanks for the replies gents. You've pointed me in the right direction.
For anyone that wants step by step instructions shoot me a PM and I'll send them your way.
