Tyre wear
france
I have got uneven wear on my front right tyre,the outer edge just disapears!!the rest of the tyre is just fine.
The rig is 1988 hj61 all standard, tyres are 31/10.5/15
any ideas?
San Francisco Bay Area
I would start with checking the front wheels to make sure the wheel bearing preload is good. Jack up the tire or the whole front of the cruiser and grab the tire at the top and bottom and push and pull make sure it is tight with no movement
https://forum.ih8mud.com/60-series-wagons/118257-wheel-bearing-preload-did-i-make-too-tight.html
Then check your front end alignment.
https://forum.ih8mud.com/60-series-wagons/76961-do-your-own-alignment.html
Also how old are the tires and were they balanced?
GLTHFJ60
Rum Runnin'
Durham, NC
I'd also check tire pressure. Additionally, if your camber is off then your axle housing is bent or the trunion bearings are shot.
