Types of engines to consider...
Spokane, Washington
My 2F still runs good, gutless but good non-the-less, but after having some leakage from the pan and the transfer case and the diff's I am considering... "The Upgrade." Instead of investing $$$ to keep the old hardware running I'd like to install a new engine and transmission. Before I do I need some help on which ones to consider. Can't think of a better place than this to get help! Thanks!
And by the way after I installed new carpet and leather upholstery I have the original carpet, which is really clean for being original, up for grabs.
Jaguar V12, Dodge RT10 (viper V10), Chevy Vortec 6.0, 5.7, 5.3, Chevy Duramax 6.6, Chrysler 426 HEMI,
Ford flathead with Ardun Hemi converison.
Your imagination is the limit.
For practicality you will want to stick with Chevy Vortec 6.0, 5.7, 5.3. It has been done a zillion times and is a proven winner.
Dynosoar
Really only one consideration for a new engine... small block GM V-8. The new versions of this setup are the 4.8, 5.3, and 6.0 liter with 4l60E auto trans. I would go with the 5.3 or 6.0 versions. You mostly likely can buy an entire engine+trans+wiring harness complete from one of the on-line salvage places, ebay or local source. THis would get you a fairly modern setup, a number of write-ups are on the forum now with this ...along with comments fromd initial day one through completion. 1 ton truck or 3/4 truck may have the 4L80E with the 6.0 engine.
2nd you might consider a 5.7 Vortec with 4l60 E, or a 5.7 TBI with 7004R trans or manual toyota 5 speed for either. Or the GM NV4500 truck manual trans.
Most likely the easy way is to use a 5.7 TBI with trans of your choice....also will be the cheapest. TBI engine is the easiset to setup and has fewer components...its also makes less horsepower, but is a decent running engine and is dependeable and easy to work on.
Most power and probally the most expensive is the 6.0 Liter family.
Parts are fairly plentful for a GM V-8, sources are SUV's, pickups, 1/2,3/4 and 1 ton trucks. If you surf through the forum I think you'll find more info on the GM V-8 swaps than anything else, plus there are a number of people who hang out here who have done the same thing.
Make sure to get the PCM the entire wiring harness and all the brackets, air filter assembly...everything. Be cool to find a engine w/trans, along with everything else.
There's really only one way to upgrade from the 2 valve, pushrod, spark ignition, naturally aspirated dinosaur engine...
4 valve, turbo, intercooled, direct injected diesel. 1HDFT and the appropriate manual trans would be my recommendation.
:cheers:
lets get a buyers group together for a casting of a one off batch of dohc injected alloy heads to bolt to the f blocks with the necessary timing gear and cams...
...and then he woke up.
:cheers:
Dare I ask what those run?
Fords are a good engine to consider, but their oil pan & pump layout makes them harder to put in an FJ than is a GM engine.
Late model Dodge/Chrysler stuff may be possible and would be worth looking into as well.
[OT] At the Antique Nationals a couple years ago there was a guy displaying his yet to be finished engine for a particular Bonneville class. Rule was that you had to use the stock Ford Model T block, beyond that it was wide open. So he built a barrel crankcase from billet aluminum that shortened the deck height by moving the crank CL up (within the original main bores) and moved from 3 to 5 mains. Then he welded two Subaru heads end to end and came up with a cog belt drive for the cams. He was waiting on the cam blanks, rods, and pistons.[/OT]
Gone Chevy
I'll give a plug for exactly what I'm running, you can see it in my signature. The NV4500 is the finest driving 5-speed I've ever tried (Chevy version, shorter throw) the ratios are spot on for a V-8 and the little bugger is silent as a tomb. The NP 241 T-case has significanty less parasitic power loss and the low range of 2.7:1 rocks. Also, it comes off as a unit and is ridiculously simple to build. Chevy axles are tough and cheap. The motor is a Gen II block with Vortec heads, basicly a carburated LT1. Just yesterday I pulled a loaded tandem axle trailer weighing at LEAST 3 tons up into the mountains and I was amazed how easily I did it. (Nice to finaly have brakes that work) Hardware makes all the difference! And I use less gas with the Chevy torque monster than the 2F did in it's wildest fantasies.
So I take it you are running GM front and rear axle assemblies, or just the rear? Not knowledgable on the GM transfercases but does that one have the front axle feed on the drivers side or the passenger side. Got any pics? pm or email them if you can, would be interested in how this worked out.
The GM NP241's for a live axle are passenger side drop. Those for the GM IFS are driver side drop.
Sign me current owner of a '91 live axle GM.
That engine is designated 1FZ-FE.
Also a nice swap into a 60, especially w/ a turbo added.
But retains the problems of having a throttle and sparking plugs.
Dodge used the NP241 on their 1/2 tons for a few years up to 1993, being the last year for the 1/2 tons. This is a desireable T-case because it is a passenger side front drop and it already has a fixed yoke out put. I had to modify the tail housing on my Chevy version NV4500 to accept the Dodge T-case, but it worked out beautifully. Ialso had to change the input gear on the T-case to accept the 32-spline Chevy shaft, but it's super easy. My front axle is Toyota, there isn't anything I like better that would make sense. I already have Longfields in it, never had a problem. FTR, Chevy used a passenger side front drop NP241 on the Blazers and Suburbans for a few years before they went to IFS on those trucks which was, I believe, 1991. These T-cases have a slip yoke output, which is complete garbage. A fixed yoke kit is available, but costs something like $400. Building one of these T-cases is the easiest thing imaginable, don't for one second be intimidated by the thought of doing it yourself. Anyway, some food for thought, I couldn't be more pleased with the setup although I'm currently running around without an E-brake, one of the project's casualties, but I will figure that out soon enough.
Hate to ask, but why even drive a Toyota? Weber carbs (your recommended fix for every stock 2F with an Aisin carb), Chevy engine and tranny, chevy axles? Flame away. I'm an ex Chevy guy. I've seen the light.:popcorn:
It seems like someone needs to work on th Toyota 4.7 swap to make it first choice and as easy to come by as the Chevy conversions for us.
I know! If Toyota made a kit for the 4.7 like Chevy does with, well, everything, I would have done it. True, I hate asian carbs no matter what they're on, and I'm not much of a fan of anything that gets big block mileage yet gets it's a$$ kicked by Geo Metros (the 2F fits into this category). Every change I have made to the rig did improve it dramaticly. The original package is ready for anything as long as you lift it a bit. At this point I have been cherry picking what I would consider to be the best parts available for the task. It's not realistic to do it this way, but if I could start from scratch and build the Perfect Cruiser, I think I would build it much like I already have. Chevy has built some great stuff over the years in terms of engines and axles, they just never built a complete vehicle that I liked. I got the most bang for the buck with the 2F with a header and a Weber, an H55F, 4.10 gears and OME springs. I could have left it that way forever, but I'm a hopeless tinkerer. And for the record, I would not ever drive a 2F with the smog junk, stock carb and exhaust. Just too gutless.
No flame! Youre right IMO.
However (as you pointed out) there is really no fesible way to get more from a Toyota engine for the bang of the CHUBBY.
I have a 5.3 vortec sitting in my garage, that is gonna mate up to a 4L60E (when I find one and have the funds) backed by and NP203 to my 19 split.
My problem is I have built the rig so much that its now essentially useless for longer trips with the SOA, 35's, rear bumper with swings, sliders etc...its a DOOOOOGGGGG!
I thought about doing a rebuild with and h55 swap, to a marlin crawl box, but it would actually be MORE to do that, than it would be to swap the chevy components, and I wouldnt really get all that much gain from it. Bulls*it IMO.
Thats just my stance on it....Id love to stick with the toy technology, but its just not performing where I need it to. On the trails...I love it. But getting to the trails...NIGHTMARE!
Chicago
Chicago
I share (ok, shared) your pain.
Anyone ever done an '85+ ('87+ for hyd roller cam) GM 4.3 V6 swap? Seems like it would have some potential. More power than stock w/o getting crazy. About 1/2 the engine weight. Nice, easy package to fit into the engine bay. A qwik search showed a stock 200HP configuration.
The conversion hardware is identical to that of the V8. So then the question is why not just do the V8? A 350 is still somewhat lighter then the 2F, twice the torque and HP using less gas. I doubt that the 4.3 would offer much of an improvement over the 2F. I think the logical thing to do there is rob the TBI hardware form the 4.3 and put it on your 2F if you gotta have six cylinders.
