- Location
- United States
SOLD SOLD SOLD
Well guys and gals, with a heavy heart I have to put these parts up for sale. Some of you may know that I was planning on a 2FE build. I have decided not to go through with it. I need to make my FJ60 a little nicer to look at, more road ready, and then get out there and explore.
The cylinder head has been rebuilt by Texon Motor Center here in Houston. It has new exhaust valves, and is ready to be installed on a 2F or 3FE block.
I will not separate these parts. I find the price more than fair for all of it.
If you are looking to do a 2FE swap just go ahead and send me a message. This is what you need.
Parts Acquired from 1991 3FE Engine (FJ80):
1991 3FE Cylinder Head (rocker assembly, valve cover, engine hooks, head bolts)
Thermostat Housing (sensors and stuff attached to it)
Complete Induction System from Air Cleaner to Intake Manifold
Exhaust Manifolds with short section of pipe
O2 sensors
Fuel Rail with Injectors
Fuel Lines
ECU - #89661-60090
Fuse Box from under the hood
Vacuum Switching Valves
Coil/ Ignitor
Distributor
EFI Harness
Heater Distribution Pipes on passenger side valve cover
Fuel Pump Block-Off Plate
New Parts:
BA 143-0657 - Beck Arnley Thermostat 180 degree
NP 671-6180 - Denso Spark Plug Wires
NG 6937 - NGK V-Power Spark Plugs (6)
FEL 9833PT - Fel-Pro Cylinder Head Gasket
FEL MS94710 - Fel-Pro Intake & Exhaust Manifold Gasket Set
FEL 35494 - Fel-Pro Thermostat Housing to Head Gasket
FEL 35307 - Fel-Pro Thermostat Housing Gasket
FEL 60910 - Fel-Pro Throttle Body Gasket
EGR Block-Off Plate (The one made by a member on the forum, FJ62INTX)
It's totally possible I may be forgetting something, ask away if you have any questions.
MUD PRICE: $1100
I will not ship these parts. They can be picked up in Houston, TX or we could work out a reasonable meeting point and small delivery fee.
Once again I will not separate these parts. I hope someone can use these or just keep them as spares.
Thank you
O2 sensors
Fuel Lines
ECU - #89661-60090
Coil/ Ignitor
Distributor
EFI Harness
New Parts:
MUD PRICE: $1100
Thank you
