I am tired of the lean to the driver side. After all the work i decided to arch my rear left spring and try to get my truck straight.
.just for a learning moment.... why stand on end instead of flat? the mating surface?
I have some STP cam break in lube you are welcome too even though they arent new or polished.
I picked up some lucas assembly lube and coated the cams and caps. It's up on end in the garage. they put a lot of masking tape on the bottom where they trued it up. Said they took off a few thou and it pressure tested clean. they got the valve stem seals in and set the valves to spec. very reasonable on price. Don't know if they cut me a break because I wasn't in a rush, and let them move a few race motors in front of me
Can someone tell me or provide a link on how to set up simple bench testing unit for the various electrical components on my rig. Heater blower, carb cooling fan, plugs, etc.....As I take this stuff off I want to verify the working condition or ID any issues I need to address. Thanks
Really! That's all I need? No power source? Thanks
Laying flat for extended periods can allow a head to warp under its own weight. The same goes for cranks.
Well, s***....hopefully I did no harm to my 2f head letting it sit flat for a week or 3.
Crazy how much I learn in this board. If only I spent as much time on a forum related to my day job...id be top of class!!
Gave my 40 a much needed face lift as my Christmas present to myself... finally hacked off the custom air restricting stadium seating style winch bimper and swapped in a new Oem bumper I bought from @tgadd several months ago.
Btw this process has taken me three days since the PO put this bumper on with no intention of it ever coming off... The weld beads were meaty as was his choice of steel supplies.
Today I salvaged the triangle brackets(kind of) and wire wheeled the sheet out of the front rails and hit it with some rust converter before installation.
I have dreams of welding a winch plate behind this bumper for my old pre-8274 warn (aka bell view or warn 5600) similar to how @Kayaker has his set up. But for now I will just bask in the glory of having a shiny part with a red and white Toyota sticker on my basket case of a rig.
The after - thankful for the guidance from @roadstr6 @fj40alex @Roxx @Rice @NCFJ @JohnVee
Btw why are ther so many holes, and even more bizarre is that there isn't any symmetry. Fog lights and license plate holder are the only factory add ons I can think of.
The before
In process
View attachment 1599713 View attachment 1599714
