So I've been fighting my AC for a few weeks now. It was initially low on charge, I put it to 2.2x ambient air temp on the high side. About a week later we are back to blowing semi-cool air on hot days. I began to suspect the Shrader valves as I noticed some bubble next to the high side when I take the cap off, also a small whoosh of gas escaping. I confirmed with the sniffer, so I am going to see if replacing the valves will seal everything up. The questions are as follows
1) Do you just vacuum from the low side ? I've seen guys doing it from L and from H and L when looking online. I will be replacing the valves on both sides.
2) After I vacuuming the charge out I was going to swap the valves which means I will lose vacuum and introduce a little air into the system. Do I need to replace the drier desiccant after this ? If so I think it's actually cheaper for me to order the Denso drier than the factory desiccant pack. What have you guys done and what part numbers have you used ?
