Two heater switches but no rear heater?
Spokane, WA
My '71 has two heater switches on the dash, but appears to never had had a rear heater in it. Also annoying is that it doesn't have a hot / cold pull to adjust the flow to the heater core. Does this sound unusual to anyone else? Currently I'm planning on using the Choke pull to install a generic temp control unit, but this extra switch has me baffled :confused:
You can pick up the rear heater off E-Bay or post up that you want one in the classified section here on MUD. You will need the heater, the lines that run to it and the wiring harness that plugs into the switch and heater. If your truck does not have them, you will need the three way splitters that allow coolant to go to both front and rear heaters.
Look under the hood for your heat control. Should be a valve on the drivers side of the head. Most replace the valve with an adjustable one like the later year Cruiser had . If you search there was a thread about the different valves available for this application. I'm using a 1972 Ford F100 heater control valve...
It doesnt sound like it would be much fun to wire up a new heater, but neither does it appear to be a lot of work.
Good luck.
Thanks for the input. I understand that I could fab a rear heater into it, what I'm confused about is why there were two controls installed from the factory, but only one heater? Shouldn't there be obvious hole in the floor if the rear was removed at some point?
Also this has a 350 in it, so unfortunately all the stock valve controls were removed.
Sure they were from the factory?
Some of the dash knobs and lights get yanked over time and it's not all that unusual for a PO to put another knob in just to cover up the hole. Hell, I've got aftermarket switches in my dash that don't have any wiring to the back of 'em at all... just to cover up the old hole after who knows what had been torn out in years past.
weren't all the tubs exact copies of each other. if so, the factory might have just put in the switch to cover the hole jsut like everyone else
My 68 came from the factory with only with a front heater. The TEEs on the firewall were solded up to the ports to the back. There are two holes to mount the rear heater. The 60/40 bench cruiser have the holes more to the passinger's side. Bucket seats holes are centered. No hard tubes in the early seventies just rubber hose with a drain in one. Your's may have had a rear heater at one time and had it removed (heater core leaked maybe) at some time. When I bought one out of a 72 out of a junk yard for my 68 I got all the rear heater, hoses, wiring and switch. If I didn't have bucket seats and have the heater centered there would be no way to tell it wasn't done at the factory. Wiring from the rear heater switch has a wire that plugs in to the other heater switch and the wire runnig to the heater. The rear heater is only single speed. Just an FYI the 73 model year was the only year that had the switches marked front and rear.
And my 73 has dual speeds for both heaters, stock. Didn't know that was the only year that had a front and rear labeled switch though.
The wiring for the rear heater is probably under the dash, mine uses a two prong plug that is like half of the molded 4wire plugs used on trailers. It also had another plug where the heater mounts, same style. It would be easy to make one up if needed. The loom ran along the floor with the heater tubes. You don't need the hard lines, hose would work fine if you find the rear heater.
I bet when someone did the 350 swap the ditched the rear heater and splitter tees inside the firwall and ran simpler straight heater hose off the 350 into the front heater core.
Some people put a ball valve right before the heater core inside the cab. Then you can adjust the heat all you want or shut it off in the summer.
Stock style was a valve on the rear of the head. I always turn mine on in late fall and make a point to turn it off June first. Sure, there are warm days around here in May, but it always seems to snow or something before the end of the month, and it sucks to get under the hood and turn the heat back on in a snow storm or cold rain.
Bringing this thread back up again as I'm going through my wiring harness and have a question for any 1971 owners.
My wiring has a three prong plug for the front heater switch and a separate blue/red wire that goes hot when the front switch is pulled to high. The rear harness as far as I could tell has a single wire that plugs into this single plug to turn on the rear heater when the front heater is in the high position.
However I have seen in several places, including the schematics I have, that the 1971 had TWO switches?
Can someone with a 1971 with both heaters tell me how your heaters are wired?
I am also looking for a 1973 rear heater switch that says 'Rear Fan' or failing that a standard H style switch. ;)
Coolerman
I have a 71 but I don't know just how much help I will be. The PO (my brother) had an electrical melt down maybe about 20 years ago. He rewired a bunch of stuff, I think primarily in the charging and ignition system so I am not sure if he did anything to the heater wires. However, I do have two switches which work independantly of each other and as far as I know they have always been that way. The switch knobs appear to be stock so I am thinking they are probably still wired stock, except for the resister on the motor under the hood being disconnected.
Hope that's of some help to you.
Don
My 69 came with both front and rear heaters, and two dash knobs. However, I put an early 72 tub on the 69 chassis, and there were no mounting holes in the tub for the rear heater.
Since I live in Southern Arizona, and have no back seats, it didn't bother me and I didn't drill and reinstall it.
My 6/71 has 2 separate controls (both labeled "H") that are completely independent of one another. Both switches have a high and low function. I'm fairly certain mine is stock, but I can't guarantee it.
:cheers:
OK, great, so they do come in a two switch configuration. Can someone with this configuration take a pic of your wiring to the switches? :D I'm thinking there was some kind of a pig tail cable that plugged into the one harness plug, and jumped over to the front and rear switch's? Pics needed of this...
Now the next question is, did some NOT come with two switches? My unmolested, OEM wiring, would seem to indicate that the rear heater could only come on when the front heater was in the high position. See pic for my wiring...
For the folks with the two speed rear heater, is there a resistor on the rear heater motor like there is on the front? How many wires go to your rear heater?
I'm not sure on the resistor to the rear heater. It may be in the heater assembly with the motor and fan, I think.
My rear heater uses a two wire harness, with the rubber molded plugs like you have pictured, but only two wires. There is a plug right at the heater, then the wires ran together, may actually be bonded together as I recall with the heater hardlines, where they had another plug below the front heater. From there I don't remember much. Seems to me though, they both had more of a plastic plug, with short pigtail, or tabs right on the switch, like the hazzard switch, or wiper switch, etc...
You know, rereading your post, newer cruisers, like 75 and up had a single switch, and I think the rear heat only kicked on at high, you still had the fresh pull knob, but the rear heat knob was replaced with a knob that said heat, and it controlled the valve on the firewall for coolant flow. The fan swich either said fan singlely or heater fan or something like that.
Perhaps, you have a newer switch in there. And perhaps the rear wires were replaced or spliced in to work like the newer system. ????????
I'm looking at the wiring digram on your website, LR, Blue with a red stripe is power in. Where are you feeding power to? Looks like the wire has to feed power to both switches, then from there they go to their respective units.
Guess I need a bigger picture of your harness you have laid out there.
My previous post is probably all BS at this time. :)
Now I'm really confused, looked at some of your project photos on your website. You do not have a two speed rear heater blower, I can tell you that. Mine has two wires, and grounds through the housing, you only have one wire on the unit you have.
Still wondering about more of the wiring harness in your picture
I found a switch labeled REAR HEAT in one of the many boxes of parts that came with my truck. I'm farily certain it was from an earlier year truck (mines a 78'). I'm also pretty sure that I've seen these in other 40's, I just don't remember where they were placed on the dash arrangement. I don't know if it is a two postion switch for a high and low or not???
If your heater switches look like the two on the right,I think they were only on '72-'73 model cruisers. There were earlier separate fan switches just labeled "H" for front and "H" for the rear. I also have several rear heaters and some are two-speed and some do not have the resistor OR the two-wire plug.
GL
Ed
:cheers:
that's how the switches are in my '72 - independent of each other; these are the H switches, each with three wires at the connector
only that I have no rear heater, so one is a dummy in the dash ;p
Ed, those are later model pulls :doh:
