My rear axle had different length u-bolts on each side. Weird. one was borderline too short while the other sides nuts were bottoming out. Ill try to find some that are in between these two I guess.
A lot of axle U-bolt makers say, they should not be re-used stating the threads are different and designed to stretch the first time they’re torqued. I’ve re-used them myself but then after I found this out, I also found a local shop that makes them to order. Not expensive and they did it in just a few minutes while I waited. They are only plain black steel, so I had to paint them. After installing I re-painted again, threads and all. If they need to come off, I’ll just cut them off and replace them again
Steamer's correct. Find a local Spring shop and they'll make them for you. Be sure to get the hardened 2H nuts and washers. Once installed' you may have to cut off a little if they are a little long.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
