Just got back to the truck after a two year hiatus. I got it running after a loose distributer wire and actually it was running pretty smooth. I drove it up and down the lane a couple time to get things cooking and then parked it in the drive and proceeded to hose down the entire inside and outside of the truck with water. It had been sitting in a mouse infested "tent" all this time and was filthy with mouse scat and dust and who knows what. Yes, I even hosed the interior of the truck as it's very bare inside and plenty of rust that a little water doesn't hurt. So I think at least. I also hosed down the engine compartment. Afterward, I turned on the engine and let it heat up to help dry. I did not notice any hesitation in starting or any rough idle. I think I then turned the car off after 10 minutes or so. A few hours later I wanted to move it and suddenly some of the cylinders weren't firing. I figured I got something wet and needed to dry it. Nothing seemed wet though I wiped down the plug wires and dist. cap inside and out. Still no luck. Ok, let it sit overnight. Today, same deal. I've narrowed it down to the cylinder nearest firewall and cylinder second in from radiator. There is no spark arriving to the plug as tested by grounding plug end to engine block. On the dist. cap, these plug leads sit side by side toward the passenger side of the car. I've checked other leads in these spaces and still no spark so not the leads. I've changed to a new dist. cap but no change. I'm getting a little fearful of the unknown. By the way, it's a Delco dist. from Mallory from way back when (no snark please). Any guesses, folks?
Many thanks!
Many thanks!
