Turn signals quit - what did I do wrong?
Tulsa, OK
Turn signal quit working - coincidence?
Folks,
Replaced ignition switch/housing/key cylinder so had the steering wheel off and moved the turn signal assembly to slide igntion assembly off (didn't disconnect turn signal plug.)
Put everything back together and now drivers side front and back works, pass side rear stays solid lit, and pass front does not light at all... When I turn hazards on the they all flash except front pass side just stays lit but doesn't flash.
So what did I do wrong?
Help would be appreciated :cheers:
Jonny
Sounds like a burnt out bulb. Replace the bulb that is not working.
Ever had a light bulb blow when you turn on a light?
After spending most of my highschool years at Circle Sunoco (in the old full service days) one thing I did learn was how to diagnose a burnt out turn signal bulb. This is a classis case.
