turn signals going nuts
Discussion in '40- & 55-Series Tech' started by fj40_rico, Jul 18, 2005.
  1. fj40_rico
    fj40_rico
    200
    Sep 11, 2003
    Orem, UT
    I finish painting the cruiser over the weekend so I took the front end appart. when I put back together I noticed that I had a blown fuse and now my turn signals won't blink and they come one when I hit the brakes. I have checked the grounds and they are all fine. Would my problem be the turn signal relay?
    Thanks.
    - Rico.
  2. dgangle
    dgangle total rice
    4,002
    20
    Nov 24, 2004
    Heart of Dixie
    I say it's a ground issue. When you press the brakes apparntly the turnsigs are finding a ground through the brake light circuit. Many moon ago I installed a Malottte fiberglass front end and missed a ground to the inner fender and all sorts of weird chit went on, electrically speaking of course.
    Try running a jumper from the body of the 1156 turnsig bulb to a good, known, clean ground (or - bat post) and tell us what happens.
  3. petescoffee
    petescoffee
    1,918
    70
    Dec 29, 2002
    Walnut Creek, CA
    Check where the washer and nut tightedn under the body as that is the ground point. Mine had paint on it and would not ground.
  4. fj40_rico
    fj40_rico
    200
    Sep 11, 2003
    Orem, UT
    Well, I started to follow wires and realized the hazard switch was pulled out and that is what was causing the issue with the turn signals. But now my hazards are not working. So back to tracing stuff.
    Actually... I don't think they've ever worked.
    thanks for the help.
    - Rico.
  5. warpdriv
    warpdriv
    3,741
    249
    Jan 10, 2003
    Austin, Tx
    I do not know about 73 (yours from the sig) but my 1/71 had a burnt turn signal switch that was freaking out the brake lights.
    hth,
  6. RUfj40crazy
    RUfj40crazy
    209
    Sep 23, 2004
    Ride in VA now in NOVA
    wiring
    Double check your wiring!!!!! My turn signal wiring was reversed on the pass. side and that fubar'd the signals and the running lights and signals on my 76'. Get out the volt meter unhook both your leads on the signals, set the turn lever and check your voltage, adjust accordingly. And always check your gounds... Happy hunting.
    Peace
    Neal
