Turn signal not working???
I tried searching for some info but I couldn't find anything! Well when I turn my turn signals to the left or right they don't work on my 1990 4runner. I've checked all the fuses and they're all good. I also I turned my hazards on the lights blink fine! What else could it be??
it could be the switch on the steering column. Im having problems with my dim/bright switch for my 91 4runner. The brights work when you pull the dimmer all the way back but when you try to switch between bright and dim it won't work. It just stays on dim.
lunyou
Yea I think its the switch itself also, I'm just going to clean out the contacts inside and see if that works!! Thanks for the info!!
Well, I finnaly got it to work! It was the fuse, it wasn't bad though, it just didn't have a good connection! I just twisted the fuses out a little bit so there would be contact and it works great now!
