1996 80 series. The passenger rear turn signal is not working. All other work.
I was working on trailer lights using the Hopkins kits, so no cutting. I unplugged all the hopkins parts and put it back to stock to diagnose.
The odd thing, is that the socket is getting power and has ground connection. I checked using a multi meter. I swapped bulbs from the other side and the other bulb does not work in the passenger side socket. I did not check to see if the turn signal was working before I started my project.
How can it show power and ground on a multi-meter and not be working. Any suggestions? Bad socket? how do I replace just the socket? I can solder in a new one but would need a PN
