Turn signal fuse (1 Viewer)
cwb
I keep popping the 7.5 amp turn signal fuse. Ideas on where to start looking?
R U saying to pull all the bulbs but one, drive it long enough so that it should blow the fuse if it's going to, then if that's not it then go to the next bulb, putting back one at a time?
If I isolate the bulb, then what?
Calling the electrical experts...
Basically, yes. You need to isolate if the issue is in the bulb holder or a chaffed wire. Intermittant shorts are a pain in the arm to figure out. It's going to take some time to trouble shoot.
How often is this happening - daily, weekly, monthly? You can also remove a bulb at time and see if the problem repeats. Be consistent and methodical. Or you might get lucky and find a frayed wire while you're looking.
Hang in there.
