- Joined
- Jun 15, 2014
- Threads
- 31
- Messages
- 349
- Location
- Tucson and Fairbanks
- Website
- www.exploringoverland.com
Some time ago I posted about the turn signal/voltage regulator fuse in my 73 FJ40 blowing and my turn signals/flashers going out. Then the fuse stopped blowing but the signals still didn't work. I finally traced the issue—I thought—to a burned connection to the hazard switch, in this thread. I repaired the connection and overhauled the hazard switch.
However, the fuse is still blowing; I'm virtually certain while I have a turn signal engaged. I noticed that the ammeter, which has always just ticked a bit in time with the signal, now swings wildly with it, as though a lot of excess power is being drawn. It does this when either signal is on.
It could be something as simple as a short in the factory harness, but finding that would seem to require stripping back the entire run between the switches and the tail lamps. I can't guess if it could still be a faulty hazard switch, which seemed fine when I took it apart except for the single burned connection in the wire that goes through the hazard switch to the turn signal switch. It seems obvious that the burned connection was the result of the issue, not the cause.
Any ideas about how to track down the exact location of the issue without just throwing parts at it?
Oh . . . I'm pretty certain it's not a ground issue because I ran a dedicated ground wire between the tail lamps and all the way back to the battery.
