Ok, so I just got the '77 rig running, after the rear amby door repair. I checked all the lights to make sure they worked, and they did. Ignition off----hazard lights worked ok. Front/rear Parking/headlights/side markers/tag worked ok. Brake lights worked ok. Now turned ignition on, turn signals worked ok, brakes/hazard still ok. Now turned on parking lights-ok, but when turn signals were turned on they clicked once, then stopped--both sides. The hazard flasher also worked, but the flash time was lengthened by about twice the time. Now the turn signals do the same thing even with the parking/headlight switch off. I took my own advice about what has changed--the only thing I did was hook up the WW squirt motor. I disconnected the thing first off and it didn't change anything. One other symptom is the horn was working, and now it's not(new horn relay). The only bad guy I can see is the turn signal switch in the column--if there is a poor(high resistance) connection there it might cause this?
Any help from you all would be greatly appreciated.
Gary
Gary
