Like Tapage, I'm finally getting around to turboing the 2h. I got a used turbo kit, I believe its a Safari unit as ARB is stamped on the manifold and it uses a Garrett turbo. My question is in regard to this piece which i'm fairly certain screws into the oil filter housing. Why are there three lines to it? Obviously there is a high pressure line, and two low pressure lines, one of which returns from the turbo. But the other? Also, do any of you have experience using this setup, or have you heard any pro's and con's using this piece as opposed to running the lines to another source. Thank you,
David
David
