- Thread starter
- #41
Huh? Use the quote at least
Ok spent the morning and $160 at the exhaust shop. I had a 2.5" exhaust put in with no muffler hoping this would solve my heat and boost issues.
There is no change at all other than sound reduction with it coming out at the back.
Any ideas? I still have a 2" pipe from my exhaust manifold to my turbo. I hope I didn't just spend money on a custom exhaust to a broken turbo that I will have to replace with something different.
What should I try next?
BC40 said:A boost gauge would tell you if the thing is moving any air. Sounds like it isn't making boost if your EGT's are rising that high with not much load and no additional power.
Does the turbine spin freely after you clocked the housing? Do you hear it whistle as the engine revs up under load? Possible air leaks? If the wastegate arm is disconnected the flap gate will be open unless you wired it shut, did you?
crushers said:did you modify the fuel setting once you installed the turbo?
i might have missed this but is it a new turbo or "new to you" turbo?
I do kinda like that setup. Although... is that PVC pipe??
Just read the entire thread. Some thoughts:
- The 2" downtube is probably fine. My BJ73 came from the factory with a tiiiiiny exhaust all the way out the back - its like 2" or 2 1/16" and it seems to breath better than my BJ42 with 2.5". Your short length of 2" adds some restriction as does the turbo itself, but not enough to explain what you're seeing.
- It really sounds like the problem is a lack of boost, a boost gauge should be the first thing you tinker with. Check the waste gate, the fact that you mucked around with is gives a greater chance that its stuck open. I wouldn't worry about the actuator for now, sort out the easy stuff first.
- The oil issues and the exhaust leak are probably irrelevant.
- Do you have the both of the venturi lines installed properly and clamped? Diaphragm in good shape?
Turned up the fuel a full turn tonight. Wow what a difference! It's like a whole new truck! I still have high heat in forth and fifth gears, but it tops out at about 1150 in third and less in first and second gear. The torque in first and second feels double what it used to be.
I have read differing opinions on what temp is safe to run at for pre turbo EGT's. Is 1200f to high for normal driving? What do you all run? I'm not sure what to do next to lower my temps. Any ideas?
I am loving the turbo 3B. I took it to a local wheeling spot and climbed some small hills and where it bogged before it holds a steady rpm now. So worth the hassle! Thanks every one for the help!
BC40 said:For normal driving, IMHO I would not be comfortable with 1200F just to keep up with in-town traffic . Steep hills at higher speeds and strong headwinds, fine. For comparison, I only get past 1200F up sustained hills in mountains in 5th (normally I would slow down and keep it more reasonable in 4th as crushers suggests). I could likely give it a little more fuel as is, or a bunch more with intercooler and more airflow, but then I'd worry about longevity. I'm keeping mine for the long haul so getting absolute max power isn't my priority, YMMV.
