I am piecing together a turbo for my 3B powered 40. I have read almost all of the turbo threads I can find (around 35 that are bookmarked now) and I have just a few questions about my oil lines and turbo position.
My turbo is a Mitsubishi off of '88 Volvo 740. It has a waste gate that from what I read is set to 12 PSI. It also has lines for coolant. It did not come with the metal stem and fitting for the oil feed line.
I had some lines made at the local industrial parts shop. They are rated for 250 f. The oil feed line I had made with the banjo fitting and bolt. It is a 14x1.25 mm and the line is 1/4 inch. The return line is a 1 inch line the I mated to the oil return line spur on the turbo and will be welding a bung to the oil pan.
Now the questions.
1st pic. Is my oil feed line to close to my turbo body? Will it melt being that close? Will a heat shroud protect it?
2nd pic. I am taking my oil feed from a plug I pulled in front of the oil pressure send. I read about it on a thread. Is this the right plug and will it send enough oil?
3rd pic. I am contemplating using the stock manifold as I am not impressed with the Isuzu manifold I have. I want to run a set up like this if I do. The oil return line would be on the top of the turbo body if I positioned it like that. Is that ok or does the oil return need to be on the bottom of the housing for proper drainage?
Thanks for your help, Isaac
Now the questions.
